Today I worked on the canopy front seal made from 2 CR/Chloroprene (Neoprene) profiles. On the sides I had to make it fit the narrow gap between the canopy frame and the fueltank. Also I did some research on how to glue india rubber (Kautschuk) pieces onto plastic. I found a contact glue that should make the job. Nevertheless, I will need to make a test prior to the job.
